[postgis-users] Question on transform.
Andy Turk
andy at streetlight.com
Wed Oct 2 16:06:00 PDT 2002
On Wednesday 02 October 2002 03:55 pm, Luis Mota wrote:
> Hi everyone.
> I've been using the transform function, but I have some surprising
> results...
> ie, exacly the same point... This is obviously wrong, since the two
> GEOGCS's are different. For instance, the prime meridian is different..
> Is it possible that I have some instalation problem? Was this a bug
> corrected in a later version?
> Thanks for any help.
> Bye, Luís
I had the same problem. Then I noticed that Proj.4 wasn't installed on that
machine. Make sure that you've got Proj.4 installed and that its library is
available to postgres.
