[postgis-users] jdbc install
Manolo mmm876 at wanadoo.es
Wed Oct 9 15:42:00 PDT 2002
I try to install postgis 0.7.3 jdbc with postgresql 7.2.x, but after make command
succeful. I cant find postgis.jar file. What happend ?
results of make command are:
javac -classpath /usr/local/pgsql/share/java/postgresql.jar:postgis.jar:. \
        org/postgis/Geometry.java \
        org/postgis/Point.java \
        org/postgis/MultiPoint.java \
        org/postgis/LineString.java \
        org/postgis/MultiLineString.java \
        org/postgis/LinearRing.java \
        org/postgis/Polygon.java \
        org/postgis/MultiPolygon.java
        org/postgis/PGgeometry.java \
        org/postgis/PGbox3d.java
javac -classpath /usr/local/pgsql/share/java/postgresql.jar:postgis.jar:. exampl
es/Test.java
java -classpath /usr/local/pgsql/share/java/postgresql.jar:postgis.jar:. example
s/Test
LinearRing Test:
(10 10 20,34 34 34, 23 19 23 , 10 10 11)
(10.0 10.0 20.0,34.0 34.0 34.0,23.0 19.0 23.0,10.0 10.0 11.0)
Point Test:
POINT(10 10 20)
POINT (10.0 10.0 20.0)
LineString Test:
LINESTRING  (10 10 20,20 20 20, 50 50 50, 34 34 34)
LINESTRING (10.0 10.0 20.0,20.0 20.0 20.0,50.0 50.0 50.0,34.0 34.0 34.0)
Polygon Test:
POLYGON ((10 10 0,20 10 0,20 20 0,20 10 0,10 10 0),(5 5 0,5 6 0,6 6 0,6 5 0,5 5
0))
POLYGON ((10.0 10.0 0.0,20.0 10.0 0.0,20.0 20.0 0.0,20.0 10.0 0.0,10.0 10.0 0.0)
,(5.0 5.0 0.0,5.0 6.0 0.0,6.0 6.0 0.0,6.0 5.0 0.0,5.0 5.0 0.0))
MultiPolygon Test:
MULTIPOLYGON (((10 10 0,20 10 0,20 20 0,20 10 0,10 10 0),(5 5 0,5 6 0,6 6 0,6 5
0,5 5 0)),((10 10 0,20 10 0,20 20 0,20 10 0,10 10 0),(5 5 0,5 6 0,6 6 0,6 5 0,5
5 0)))
MULTIPOLYGON (((10.0 10.0 0.0,20.0 10.0 0.0,20.0 20.0 0.0,20.0 10.0 0.0,10.0 10.
0 0.0),(5.0 5.0 0.0,5.0 6.0 0.0,6.0 6.0 0.0,6.0 5.0 0.0,5.0 5.0 0.0)),((10.0 10.
0 0.0,20.0 10.0 0.0,20.0 20.0 0.0,20.0 10.0 0.0,10.0 10.0 0.0),(5.0 5.0 0.0,5.0
6.0 0.0,6.0 6.0 0.0,6.0 5.0 0.0,5.0 5.0 0.0)))
MultiLineString Test:
MULTILINESTRING ((10 10 0,20 10 0,20 20 0,20 10 0,10 10 0),(5 5 0,5 6 0,6 6 0,6
5 0,5 5 0))
MULTILINESTRING ((10.0 10.0 0.0,20.0 10.0 0.0,20.0 20.0 0.0,20.0 10.0 0.0,10.0 1
0.0 0.0),(5.0 5.0 0.0,5.0 6.0 0.0,6.0 6.0 0.0,6.0 5.0 0.0,5.0 5.0 0.0))
PG Test:
5 0,5 5 0))
servidor:/usr/local/src/postgresql-7.2.1/contrib/postgis-0.7.3/
Thanks
