[postgis-users] [Fwd: Error using pgsql2shp]
Obe, Regina DND\MIS
robe.dnd at ci.boston.ma.us
Thu Oct 10 07:59:41 PDT 2002
Did you check to see if you have null values in your geometry field. I had
that problem when I had null values in my geometry field, but did a view
leaving out the nulls and exported the view instead of the table.
-----Original Message-----
Sent: Thursday, October 10, 2002 11:02 AM
To: postgis-users at postgis.refractions.net
Subject: [postgis-users] [Fwd: Error using pgsql2shp]
Hi.
I sent this message about a week ago. In the meantime, I upgraded to
version 0.7.3, but the result is the same. Can anyone give me a hint on
this?
Bye and thanks, Luís
-------- Original Message --------
Subject: Error using pgsql2shp
Date: Thu, 03 Oct 2002 04:17:08 +0100
References: <3D99BA66.EA3EBB51 at geo.unizh.ch>
<3D9AA5F3.F3928CD9 at geo.unizh.ch> <3D9B857E.68FB203A at refractions.net>
<200210021714.39833.andy at streetlight.com>
Hi.
I was trying to export one of my tables to a shapefile, issuing the command
pgsql2shp -f /trabalho/bd/location.shp -g geom gis_teste2 location
but I get the following error:
ERROR: Cannot have multiple geometry types in a shapefile.
What surprises me is that this table has no multiple geometry, as you
can see by its description, included at the end.
Am I not understanding this correctly?
Bye, Luís
Table "location"
Column | Type |
Modifiers
slqtid | integer | not null default
nextval('"location_slqtid_seq"'::text)
gID | integer |
x | double precision |
y | double precision |
z | double precision |
pcsID | integer |
pcsAuthor | text |
latitude | double precision |
longitude | double precision |
height | double precision |
gcsID | integer |
gcsAuthor | text |
publicPlaceType | text |
publicPlaceName | text |
buildingName | text |
buildingSubdivisionType | text |
buildingSubdivisionName | text |
numberType | text |
doorNumber | text |
floorName | text |
floorSideName | text |
zipCode | text |
cityName | text |
stateName | text |
countryName | text |
language | text |
geom | geometry |
dummy | boolean | default 'f'::bool
Primary key: location_pkey
Check constraints: "$1" (srid(geom) = 20790)
"$2" ((geometrytype(geom) = 'POINT'::text) OR
(NULL::geometry = geom))
Rules: loc_insert
Triggers: RI_ConstraintTrigger_994633,
RI_ConstraintTrigger_994631,
RI_ConstraintTrigger_994621,
RI_ConstraintTrigger_994619,
RI_ConstraintTrigger_994609,
RI_ConstraintTrigger_994607
postgis-users mailing list
http://postgis.refractions.net/mailman/listinfo/postgis-users
