[postgis-users] [Fwd: Error using pgsql2shp]
Jeff Lounsbury
jeffloun at refractions.net
Thu Oct 10 10:43:48 PDT 2002
I have added support to write out null geometries into pgsql2shp and commited it
to CVS.
I have not tested every type of geometry but it is implemented for every type.
-Jeff
Paul Ramsey wrote:
> Shape files support null geometries, I am pretty sure, so we should be
> able to handle this case gracefully... I wonder if it is just the
> typechecking which cacks, or if there is code farther down the line
> which would also have to be altered. Jeff?
> Obe, Regina DND\MIS wrote:
> > Did you check to see if you have null values in your geometry field. I had
> > that problem when I had null values in my geometry field, but did a view
> > leaving out the nulls and exported the view instead of the table.
> > -----Original Message-----
> > From: Luis Mota [mailto:luis.mota at iscte.pt]
> > Sent: Thursday, October 10, 2002 11:02 AM
> > To: postgis-users at postgis.refractions.net
> > Subject: [postgis-users] [Fwd: Error using pgsql2shp]
> > Hi.
> > I sent this message about a week ago. In the meantime, I upgraded to
> > version 0.7.3, but the result is the same. Can anyone give me a hint on
> > this?
> > Bye and thanks, Luís
> > -------- Original Message --------
> > Subject: Error using pgsql2shp
> > Date: Thu, 03 Oct 2002 04:17:08 +0100
> > From: Luis Mota <luis.mota at iscte.pt>
> > References: <3D99BA66.EA3EBB51 at geo.unizh.ch>
> > <3D9AA5F3.F3928CD9 at geo.unizh.ch> <3D9B857E.68FB203A at refractions.net>
> > <200210021714.39833.andy at streetlight.com>
> > Hi.
> > I was trying to export one of my tables to a shapefile, issuing the command
> > pgsql2shp -f /trabalho/bd/location.shp -g geom gis_teste2 location
> > but I get the following error:
> > ERROR: Cannot have multiple geometry types in a shapefile.
> > What surprises me is that this table has no multiple geometry, as you
> > can see by its description, included at the end.
> > Am I not understanding this correctly?
> > Bye, Luís
> > Table "location"
> > Column | Type |
> > Modifiers
> > slqtid | integer | not null default
> > nextval('"location_slqtid_seq"'::text)
> > gID | integer |
> > x | double precision |
> > y | double precision |
> > z | double precision |
> > pcsID | integer |
> > pcsAuthor | text |
> > latitude | double precision |
> > longitude | double precision |
> > height | double precision |
> > gcsID | integer |
> > gcsAuthor | text |
> > publicPlaceType | text |
> > publicPlaceName | text |
> > buildingName | text |
> > buildingSubdivisionType | text |
> > buildingSubdivisionName | text |
> > numberType | text |
> > doorNumber | text |
> > floorName | text |
> > floorSideName | text |
> > zipCode | text |
> > cityName | text |
> > stateName | text |
> > countryName | text |
> > language | text |
> > geom | geometry |
> > dummy | boolean | default 'f'::bool
> > Primary key: location_pkey
> > Check constraints: "$1" (srid(geom) = 20790)
> > "$2" ((geometrytype(geom) = 'POINT'::text) OR
> > (NULL::geometry = geom))
> > Rules: loc_insert
> > Triggers: RI_ConstraintTrigger_994633,
> > RI_ConstraintTrigger_994631,
> > RI_ConstraintTrigger_994621,
> > RI_ConstraintTrigger_994619,
> > RI_ConstraintTrigger_994609,
> > RI_ConstraintTrigger_994607
> > postgis-users mailing list
> > http://postgis.refractions.net/mailman/listinfo/postgis-users
> __
> | Paul Ramsey
> | Refractions Research
> | Email: pramsey at refractions.net
> | Phone: (250) 885-0632
> \_
