[postgis-users] Spatial operators
Luis Mota luis.mota at iscte.pt
Fri Oct 11 01:05:09 PDT 2002
Craig:
thanks for your suggestion, but, in the portuguese case, zip codes are
attributes of the 'left-hand-side' and 'right-hand-side' of a
linestring. I got the data direcly from portuguese mail company...
Bye, Luís
Craig Miller wrote:
>Since zip codes refer to polygons, perhaps you could use this data to first
>attribute the polygons.  Then you can simply determine which polygon the
>point is inside to determine the zip code.
