[postgis-users] Problem with subselects
David Blasby dblasby at refractions.net
Tue Oct 22 09:07:39 PDT 2002
Jan,
Are you using the most up-to-date mappostgis.c from the CVS?
If you're not, there are a few known problems with sub-selects and using
more-than-one-subselect-in-a-mapfile that this version fixes.
Also, it will give you much more detailed error messages.
dave
ps. I've encluded the  mappostgis.c file.  Replace your version with
this then recompile and install.
Type: application/x-unknown-content-type-cfile
Desc: not available
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20021022/4d7828ac/attachment.bin>
