[postgis-users] Upgrade...
Joao Brezolin
gispmpf at yahoo.com.br
Fri Oct 25 12:50:35 PDT 2002
Hello,
I have upgraded from pgsql 7.1.3 to pgsql 7.2.3 and
from postgis 0.5.1 to 0.7.3 ...
the only error is when i execute the psql -f db -f
postgis
witch says "geometry type is not ready yet..."
and in the apaci's error log says "Image could be
created"...
How can i fix this errors?
Do you get no error message at all? You should test
using mapserver's
command-line shp2img (command line is generally more
convenient and browsers
don't always show you the error message properly. If
you still don't get an
error message, all I can do is recommend the newest
mapserver (3.6) - and
get the mappostgis.c file out of mapserver's cvs as it
has WAY better error
reporting.
Chris
----- Original Message -----
To: <postgis-users at postgis.refractions.net>
Sent: Monday, October 21, 2002 7:17 AM
Subject: [postgis-users] Upgrade problem
> Hello all,
> I'm using mapserver 3.5 and after the upgrade
process
> nothing seems to be working...
> when i start mapserver with postgis it returns a
blank
> page insted the geometry draw...
> any ideia what could be wrong??
> Thanks
> João
_______________________________________________________________________
Yahoo! GeoCities
Tudo para criar o seu site: ferramentas fáceis de usar, espaço de sobra e acessórios.
http://br.geocities.yahoo.com/
