SV: [postgis-users] Installing Postgres in Cygwin - win XP
Kjell-Olav Bjerknes
kob at norkart.no
Mon Oct 28 01:22:00 PST 2002
Hi.
The postgres.exe file is in the /bin catalog and the user "postgres" is allowed to run it.
Now my cygipc is running as a service, but I still get:
FATAL 1: /usr/bin/postgres: could not locate executable, bailing out...
initdb failed.
when I try to initdb!
Any ideas?
Kjell-Olav
-----Opprinnelig melding-----
Fra: Obe, Regina DND\MIS [SMTP:robe.dnd at ci.boston.ma.us]
Sendt: 25. oktober 2002 15:48
Til: 'postgis-users at postgis.refractions.net'
Emne: RE: [postgis-users] Installing Postgres in Cygwin - win XP
Actually I take back my last statement about size. My newer version is 2.6
MB and is located in my /bin folder instead of /usr/bin, but I think this
varies depending on how you configure your install (location and size).
-----Original Message-----
From: Kjell-Olav Bjerknes [mailto:kob at norkart.no]
Sent: Friday, October 25, 2002 3:46 AM
To: 'postgis-users at postgis.refractions.net'
Subject: [postgis-users] Installing Postgres in Cygwin - win XP
Hi..
I'm having problems installing Postgres in Cygwin on a Windows XP machine.
I followed the The NON-UNIX User's Guide to Installing PostGIS on Windows
but it fails during initdb.
I installed the cygipc-1.11-1.tar.bz2 and ran it as a servcie; ipc-daemon
--install-as-service
I made the postgres user etc, but when I log on to my pc as postgres and
run initdb it hangs... using 100% cpu for a long time. (how much time
should this take?) after some time ca 20-30 min I break out
to get my CPU back....
If I start the ipc-daemon manually I get this:
$ ipc-daemon &
[1] 1316
postgres at KOB-DELL /
$ mkdir /usr/share/postgresql/data
$ initdb -D /usr/share/postgresql/data
The files belonging to this database system will be owned by user
"postgres".
This user must also own the server process.
Fixing permissions on existing directory /usr/share/postgresql/data... ok
creating directory /usr/share/postgresql/data/base... ok
creating directory /usr/share/postgresql/data/global... ok
creating directory /usr/share/postgresql/data/pg_xlog... ok
creating directory /usr/share/postgresql/data/pg_clog... ok
creating template1 database in /usr/share/postgresql/data/base/1... ok
creating configuration files... ok
initializing pg_shadow... FindExec: invalid binary "/usr/bin/postgres"
initdb failed.
Does anyone have any idea???
kjell-olav
postgis-users mailing list
http://postgis.refractions.net/mailman/listinfo/postgis-users
