[postgis-users] problems with StartPoint(Geometry) and EndPoint(Geometry)?
Dave Blasby
dblasby at refractions.net
Fri Sep 13 16:08:35 PDT 2002
Andy Turk wrote:
> Both StartPoint() and EndPoint return NULL for me when I try to use them in
> 0.73. However, PointN() works just fine.
> Try this and see what you get:
> SELECT StartPoint(GeometryFromText('MULTILINESTRING((0 0,1 1))', 1));
> startpoint
> (1 row)
According to the OGC spec, "StartPoint()" is only defined for
linestrings - not multilinestrings.
If you want to use multilinestrings, use StartPoint(GeometryN(<mult>,
dave
