[postgis-users] Re: [Mapserver-users] Mapserver query click returns PostGIS query error
Richard Greenwood
Rich at GreenwoodMap.com
Fri Apr 4 12:56:52 PST 2003
>"There's a problem with the postgis-mapserver connector with postgresql
>7.3. I know about it, I'm just really busy and havent had time to fix
>it. Hopefully within the next week or so."
That sure sounds like the problem that I am encountering. My 7.2.3 works,
while my 7.3.2 fails. Also interesting is that I see a series of server
errors from postmaster when attempting to fetch attribute data. I'm not at
that machine now, but they all had something to do with a broken connection.
One other interesting point that I failed to mention in my previous posting
is that postgis is returning the correct record count, it just fails to
return the actual contents of those records.
Best regards,
Rich
>...or the following from Stefan Schneberger:
>"have look at the postgis mailing-list, there is a patch for mapserver
>3.6.3. You will find it here:
>http://postgis.refractions.net/pipermail/postgis-users/2002-December/001862.
>html"
>Sounds like a solution is on the way.
>Best,
>Jonathan
>On Thu, 2003-04-03 at 20:16, Richard Greenwood wrote:
> > What's your postgresql running on - linux or cygwin? I am having a similar
> > problem. Mine runs correctly on linux but not on cygwin. There are a few
> > other minor differences between my two setups, so I can't say conclusively
> > that's it is related to OS.
> > I posted my issue to the postgis list, and have pasted in below, but thus
> > far I haven't made any headway.
> > === my post to postgis-users at postgis.refractions.net ===
> > I have a simple mapserver/postgis running with mapserver on windows and
> > postgresql on linux. All the recent discussion of postgis on cygwin
> > motivated me to give it a try.
> > I can map from cygwin-postgis, but I can not retrieve attribute data with
> > the mapserver query or nquery modes. I get the following error:
> > msPOSTGISLayerGetShape(): Query error. Error executing POSTGIS SQL
> > statement (in FETCH ALL): EXPLAIN VERBOSE SELECT * FROM join_region -
> Error
> > with POSTGIS data variable. You specified ''.
> > My linux setup, which works correctly, is postgresql 7.2.3, postgis 0.7.3
> > My cygwiwn setup, which fails, is postgresql 7.3.2, postgis 0.7.4
> > Everything else is basically the same.
> > Best regards,
> > Rich
> > At 06:06 PM 4/3/2003 -0800, you wrote:
> > >Hello List:
> > >When serving maps with Mapserver 3.6.3 on RedHat Linux v.8 and pulling
> data
> > >from PosgreSQL v.7.3.1 with PostGIS v.0.7.4 using the following map file
> > >parameters...
> > >LAYER
> > > NAME "parcels"
> > > CONNECTION "user=xxx password=xxx dbname=xxx host=xxx port=5432"
> > > DATA "the_geom from pcl_b83m"
> > > TYPE POLYGON
> > > HEADER "parcel_header.html"
> > > FOOTER "parcel_footer.html"
> > > CLASS # parcels class
> > > NAME "property boundaries"
> > > COLOR 245 245 245
> > > TEMPLATE "parcel_query.html"
> > > END
> > >END
> > >..the layer draws perfectly, but when queried (by clicking on the map in
> > >query
> > >mode), the following error returns:
> > > msPOSTGISLayerGetItems(): Query error. Error executing POSTGIS SQL
> > > statement:
> > >EXPLAIN VERBOSE SELECT * FROM pcl_b_83m
> > >The SQL statement, "EXPLAIN VERBOSE SELECT * FROM pcl_b_83m" runs fine
> > >from the
> > >PostgreSQL SQL interpreter command line.
> > >Both the mapserver and postgis archives had some good suggestions
> (e.g. use
> > >of '-1' as an SRID causes problems with some versions, upper case in
> the SQL
> > >statement causes some problems, etc.), but none were the solution I
> needed.
> > >Any suggestions for a next step in debugging this? I suspect some simple
> > >missing piece.
> > >Potential clues (or additional debugging problems)...
> > >The following two approaches to displaying the same data produce different
> > >results:
> > >1) DATA "the_geom from (select pcl_b_83m.the_geom as the_geom,
> pcl_b_83m.oid
> > >as oid, address.name as aname from pcl_b_83m left join address on
> > >pcl_b_83m.addrid = address.id) as pcl_adr using unique oid using
> srid=26943"
> > > ...this one (1 above) successfully displays the polygons.
> > >2a) CREATE VIEW pcl_view as select pcl_b_83m.the_geom as the_geom,
> > >pcl_b_83m.oid as oid, address.name as aname from pcl_b_83m left join
> > >address on
> > >2b) DATA "the_geom from pcl_view as pcl_adr using unique oid using
> > >srid=26943"
> > > ...these two (2a and 2b above) do not cause an error, but also do not
> > > display
> > >the data.
> > >So, a view based on the same SQL as a temporary table fails. (Not a
> > >showstopper, as one of the choices works, but I would prefer to use
> the view
> > >approach to take advantage of caching within PostgreSQL.)
> > >This is included in case it sheds light on the primary question--why the
> > >query
> > >error?
> > >SWAGs welcome.
> > >Thank you!
> > >Jonathan W. Lowe
> > >email - jlowe at giswebsite.com
> > >website - http://www.giswebsite.com
> > >_______________________________________________
> > >Mapserver-users mailing list
> > >Mapserver-users at lists.gis.umn.edu
> > >http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
> > Richard W. Greenwood, PLS
> > (307) 733-0203
> > www.GreenwoodMap.com
Greenwood Mapping, Inc.
(307) 733-0203
http://www.GreenwoodMap.com
