[postgis-users] CVS Stability
Paul Ramsey
pramsey at refractions.net
Tue Apr 8 20:59:26 PDT 2003
Sorry, Norman, I'm taking the cowards way out.
I have released a 0.7.5, which holds all the bug fixes since 0.7.4.
This will have to hold everyone together until the 0.8 release. I do
not anticipate the delay from now until 0.8 should be all that long
(one month max) and we really do not have enough parallel development
(or a sufficiently well defined release cycle) to warrant running a
separate branch for the stable tree at this time. When the time comes
for the bottom-up rewrite which Dave keeps talking about, we will fork
a stable branch.
So, my warning stands: use the CVS version only if you're in an
experimental mood.
Paul
On Tuesday, April 8, 2003, at 02:48 PM, Norman Vine wrote:
> Paul Ramsey writes:
>> To repeat: until the next numbered release (0.8) is out, do not use
>> the
>> CVS snapshots unless you are willing to work with experimental and
>> tempermental code.
> Why not make a branch for the new GEOS enabled PostGIS
> and then merge the branch back in once we have the GEOS
> issues ironed out ?
> http://cvsbook.red-bean.com/cvsbook.html#Branches
> This way the CVS PostGIS remains 'solid'
> Cheers
> Norman
> postgis-users mailing list
Paul Ramsey
Refractions Research
Email: pramsey at refractions.net
Phone: (250) 885-0632
