[postgis-users] About $libdir
Norman Vine
nhv at cape.com
Fri Apr 11 09:31:05 PDT 2003
Paul Ramsey writes:
> While, I often thing a standalone postgis with a configure script would
> be an improvement, the number of potential cases due to packagers doing
> inconsistent things with their various distributions (in the FreeBSD
> case it appears that the binary package had a different configuration
> from the source package, same with the Cygwin case) might defeat any
> attempt at automatically finding all the information needed for a compile.
AFAICT installing from within the PostgreSQL source distribution is needed
as PostGIS uses some of the internal PSQL headers.
AFAICT the $libdir problem is self inflicted in that because we use
include $(top_srcdir)/src/Makefile.shlib
instead of
include $(top_srcdir)/contrib/contrib-global.mk
the 'normal' install location for the $SO_LIB is not available
note It is not trivial to use 'contrib-global.mk' in that we are
building both a $SO_LIB and EXEs but it is probably worth
looking into using the 'contrib-global.mk' functionality if ....
someone has the time and the inclination
Cheers
Norman
