[postgis-users] Error handling: GEOS throws in PostGIS.
Norman Vine
nhv at cape.com
Fri Apr 11 17:33:54 PDT 2003
Martin Davis writes:
> Is what you're suggesting this:
> Catch all GEOS errors internally and return a status code
> instead. If a method already has a return value, return NULL
> This seems like a pretty substantial change to GEOS. Does it
> mean that everyone using GEOS now has to check return codes,
> instead of using exceptions?
Fortunately I don't think this is what Dave is suggesting see below
> Is there any way of providing a yet higher wrapper in between
> GEOS and PostGIS which converts exceptions into return codes (so
> that GEOS is kept pure and PostGIS can call it safely)?
YES !!
This is the 'C' wrapper layer that PostGIS needs
The GEOS C++ code does not need to change as it will be
the responsibility of the 'C' wrapper to map the GEOS errors
into 'C' return codes
>> Dave wrote:
> > So, unless anyone has any bright ideas, we could think about
> > putting a C
> > api directly in GEOS. If we use the standard C way of error handling
> > (return an error code or NULL, like in the above), PostGIS
> > should have
> > no problems. Unfortunately, this does
> > "pollute" GEOS.
> > What think?
Sounds like a plan to me
Cheers
Norman
