[postgis-users] Call for Debuggers
Carl Anderson
carl.anderson at vadose.org
Tue Apr 15 21:15:06 PDT 2003
Ok in what context does "instant segfault" occur
I compiled geos on a Solaris 5.7 with gcc3.2.2 using GNU ld
autoheader-1.6
automake-1.6 --add-missing --gnu
autoconf
configure CXXFLAGS="-g" CFLAGS="-g"
make
Notice that I'm disabling the default CXXFLAGS "-g -O2"
Paul the autogen.sh calls a default aclocal and automake. Many (i
don't know if all)
automake ver 1.6 install themselves as automake-1.6 in addition to
automake.
(same for aclocal-1.6)
I have both automake-1.4 and automake-1.6 installed. geos does not
compile with automake-1.4 so that may be part of the issue.
then run tests
source/test/CTS
ok
source/test/XMLTester
ok
source/test/SimpleWKTTester
ok
source/example/CoordinateListsExample
ok
source/example/CustomCoordinateListExample
ok
Are there other tests to run.
C.
