[postgis-users] shp2pgsql bug?
Zhiqiang Zhang
zzhang01 at hotmail.com
Fri Apr 18 11:54:36 PDT 2003
Thanks for the prompt reply. What's the temporary solution before a patch is
come up? I am using postgis 0.7.5. Does the older version also has the same
problem?
>From: Paul Ramsey <pramsey at refractions.net>
>Reply-To: PostGIS Users Discussion <postgis-users at postgis.refractions.net>
>Subject: Re: [postgis-users] shp2pgsql bug?
>Date: Fri, 18 Apr 2003 08:37:27 -0700
>It looks like you have a bad int8 external representation. :)
>Seriously, it looks like the new handling for large numbers does not
>include handling for nulls. You'll have to patch the loader yourself or
>wait for a patch from us or someone else.
>On Friday, April 18, 2003, at 01:36 AM, Zhiqiang Zhang wrote:
>>I am trying to load a shapefile into postgis using shp2pgsql tool:
>>shp2pgsql myfile roads sdb > roads.sql
>>The roads.sql was generated but when I try to run
>>psql -d sdb -f roads.sql I got the following error:
>>ERROR: Bad int8 external representation "".
>>Anybody knows what's wrong?
>>The roads.sql looks like:
>>create table roads (gid int4 , TLID int8, FNODE int4, TNODE int4, LENGTH
>>float8, FEDIRP varchar, FENAME varchar, FETYPE varchar, FEDIRS varchar,
>>CFCC varchar, FRADDL int8, TOADDL int8, FRADDR int8, TOADDR int8, ZIPL
>>varchar, ZIPR varchar, CENSUS1 varchar, CENSUS2 varchar, CFCC1 varchar,
>>CFCC2 varchar, SOURCE varchar);
>>select
>>AddGeometryColumn('sdb','roads','the_geom','-1','MULTILINESTRING',2);
>>begin;
>>insert into roads
>>values('0','102598387','52476','52477','0.16860',NULL,NULL,NULL,NULL,'A
>>41','','','','',NULL,NULL,'0','0','A','A4','A',GeometryFromText('MULTIL
>>INESTRING ((-121.271077 37.168284 ,-121.268691 37.169473 ,-121.268443
>>37.169496))',-1) );
>>It fails at the first insert.
>>Any help will be greatly appreciated.
>>MZ
>>_________________________________________________________________
>>Help STOP SPAM with the new MSN 8 and get 2 months FREE*
>>http://join.msn.com/?page=features/junkmail
>>postgis-users mailing list
>>http://postgis.refractions.net/mailman/listinfo/postgis-users
> Paul Ramsey
> Refractions Research
> Email: pramsey at refractions.net
> Phone: (250) 885-0632
STOP MORE SPAM with the new MSN 8 and get 2 months FREE*
