[postgis-users] Re: failure to load postgis.sql
Byron Amerson
byronea at u.washington.edu
Mon Dec 1 11:09:20 PST 2003
I am not at the computer where I am attempting to build postgis, none the
less,
in attempting the following LDFLAGS=-lstdc ./compile
my system barked that it did not know the command LDFLAGS.
So I set an environment variable like so:
setenv LADFLAGS -lstdc
and indeed it showed up as LDFLAGS=-lstdc when I checked using env.
so I went ahead and compiled.
evidently this either did not work as expected or was not the right way to
proceed.
Byron Amerson
MS student
University of Washington
Department of Earth and Space Sciences
