[postgis-users] Solaris 8, postgis 0.8.0, pg 7.4 compile error
David Valentine
valentine at library.ucsb.edu
Mon Dec 1 23:45:06 PST 2003
all the latest goodies from sunfreeware.com
gcc3.3.2, binutils, coreutils, bison, flex, m4, make
libgcc 3.3 (even though it should not be needed)
tried aliasing ld, ar,ranlib, as to /usr/ccs/bin versions,
trying on a different machine on the next attempt.
On Dec 1, 2003, at 9:04 PM, Paul Ramsey wrote:
> Do you have the GNU stdc++ libraries installed?
> Just guessing wildly here... I got a clean Solaris compile (Solaris
> 6!) but I had to make sure I had *all* the GNU tools, linker,
> compiler, libraries, etc, not just some.
> David Valentine wrote:
>> solaris8
>> gcc 3.3.2
>> postgis 0.8.0
>> pg 7.4
>> geos-1.0
>> proj-4.4.7
>> LD_LIBRARY_PATH=/usr/local/ssl/lib:/usr/local/lib:/usr/lib:/lib:/usr/
>> ccs/lib
>> PATH=/usr/local/pgsql/bin:/usr/local/ant/bin:/usr/sbin:/usr/local/
>> sbin: /usr/
>> local/bin:/usr/bin:/usr/ccs/bin
>> PG_HOME=/usr/local/pgsql
>> GEOS_DIR=/usr/local
>> I've done:
>> LDFLAGS=-lstdc++ ./configure
>> # cd /usr/local/src/postgresql-7.4/contrib/postgis-cvs
>> # /usr/local/bin/make
>> [snip]
>> gcc -shared -h libpostgis.so.0 postgis_debug.o postgis_ops.o
>> postgis_fn.o
>> postgis_inout.o postgis_proj.o postgis_chip.o postgis_transform.o
>> postgis_gist_72.o postgis_estimate.o postgis_geos.o
>> postgis_geos_wrapper.o
>> postgis_algo.o -L../../src/port -L../../src/port -lstdc++
>> -L/usr/local/lib
>> -lgeos -L/usr/local/lib -lproj -R/usr/local/pgsql/lib -o
>> libpostgis.so.0.8
>> Text relocation remains referenced
>> against symbol offset in file
>> <unknown> 0x2a28 postgis_geos_wrapper.o
>> <unknown> 0x2a2c postgis_geos_wrapper.o
>> <unknown> 0x2a30 postgis_geos_wrapper.o
>> <unknown> 0x2a34 postgis_geos_wrapper.o
>> <unknown> 0x2a38 postgis_geos_wrapper.o
>> <unknown> 0x2a3c postgis_geos_wrapper.o
>> <unknown> 0x2a40 postgis_geos_wrapper.o
>> free 0x33d8 postgis_geos_wrapper.o
>> NOTICE_MESSAGE 0x214 postgis_geos_wrapper.o
>> [snip]
>> _Unwind_Resume 0x414c postgis_geos_wrapper.o
>> _Unwind_Resume 0x4258 postgis_geos_wrapper.o
>> ld: fatal: relocations remain against allocatable but non-writable
>> sections
>> collect2: ld returned 1 exit status
>> make: *** [libpostgis.so.0.8] Error 1
>> postgis-users mailing list
>> postgis-users at postgis.refractions.net
>> http://postgis.refractions.net/mailman/listinfo/postgis-users
> __
> | Paul Ramsey
> | Refractions Research
> | Email: pramsey at refractions.net
> | Phone: (250) 885-0632
> \_
