[postgis-users] problem intersection with postgis on multipolygon
David TECHER davidtecher at yahoo.fr
Fri Dec 12 11:17:28 PST 2003
Hi
I have to use function intersection for 3 tables with
thousand lines.
All my 'the_geom' tables are 'MULTIPOLYGON'
But when I used intersection() on it, postgresql
scratched :(
So I gave up this function and use the geos project to
make a *.exe program that parse a xml file with my
data from 'the_geom column':
<run>
<a>
MULTIPOLYGON....
</a>
<b>
</b>
<test>.....
When I opened ma data from the_geom column, I
use geometryn(the_geom,integer) to see every geometric
data..
I saw that I have POLYGON((.....),(.....),(....))
Is it possible?????
Because when I use JTS to find the intersection from
the xml file or geos it said:
Exception...Number of points must be 0 or >3
Please help
thanks
Notice: I uses shp2pgsql to convert my data from
mapInfo to postgis
My configuration is
Windows XP¨, postgresql-7.3.4, postgis 0.8.0, geos 1.0
proj 4.4.7
_________________________________________________________________
Do You Yahoo!? -- Une adresse @yahoo.fr gratuite et en français !
Yahoo! Mail : http://fr.mail.yahoo.com
