[postgis-users] shp2pgsql and schemas
David Blasby
dblasby at refractions.net
Fri Dec 12 11:33:51 PST 2003
> EXECUTE ''ALTER TABLE '' || quote_ident(schema_name) || ''.'' || quote_ident(table_name) || '' ADD COLUMN '' || quote_ident(column_name) || '' geometry '';
> The EXECUTE ''ALTER TABLE '' line gives me the syntax error:
> psql:toload.txt:2: ERROR: syntax error at or near "$3" at character 70
> CONTEXT: PL/pgSQL function "addgeometrycolumn" line 69 at return
> when trying to load a file created by shp2pgsql.
> Does anyone know what the error is or how to output the command that is
> being created from this line? I have tried using echo but I cant get this
> to work. For example, all I want sent to postgres given above input is:
> ALTER TABLE roads.carrolls_route_alberta_test ADD COLUMN the_geom geometry;
above the "EXECUTE" line, add (change EXECUTE to RAISE NOTICE):
RAISE NOTICE ''ALTER TABLE '' || quote_ident(schema_name) || ''.'' ||
|| '' geometry '';
dave
