[postgis-users] shp2pgsql and schemas
strk
strk at keybit.net
Mon Dec 15 08:20:35 PST 2003
Schema handling is not supported by current postgis version.
I'd suggest you set your search_path so to have the schema you'd
like the table to be created in as the first listed.
Using schema.table will not work when fed to AddGeometryColumn.
--strk;
carrolls wrote:
> The updated code is:
> input := ''ALTER TABLE '' || quote_ident(schema_name) || ''.'' || quote_ident(table_name) || '' ADD COLUMN '' || quote_ident(column_name) || '' geometry '';
> RAISE NOTICE ''input: %'', input;
> EXECUTE input;
> RAISE NOTICE exec finished;
> And the new output is:
> psql:toload.txt:2: ERROR: syntax error at or near "exec"
> CONTEXT: compile of PL/pgSQL function "addgeometrycolumn" near line 43
> No output is given for the first RAISE NOTICE. The the_geom column is
> still not added to the created table.
> Seamus
> On Fri, 12 Dec 2003, David Blasby wrote:
> > Seamus Thomas Carroll wrote:
> > > I have changed the code to:
> > > EXECUTE input;
> > > and the output is now:
> > > psql:toload.txt:2: NOTICE: input: ALTER TABLE roads.carrolls_route_alberta_test ADD COLUMN the_geom geometry
> > > psql:toload.txt:2: ERROR: syntax error at or near "$3" at character 70
> > > CONTEXT: PL/pgSQL function "addgeometrycolumn" line 69 at return
> > > if I copy the result of the notice and paste it into the psql prompt it
> > > works without error.
> > > Could this be a error in posgtres that is causing a syntax error when one
> > > is not present?
> > Try putting a "RAISE NOTICE exec finished" immediately after the EXECUTE.
> > dave
> > postgis-users mailing list
> > postgis-users at postgis.refractions.net
> > http://postgis.refractions.net/mailman/listinfo/postgis-users
