[postgis-users] invoking inverse transforms
Tony doppelganger at doppelganger.org
Sun Dec 21 18:39:56 PST 2003
So if I take an existing entry's proj text, add the +inv argument, and
throw in a unique new SRID,
should that do it?
For example, the forward transform uses the following arguments:
+proj=lcc +lat_1=41.71666666666667 +lat_2=42.68333333333333 +lat_0=41
+lon_0=-71.5 +x_0=200000 +y_0=750000 +ellps=GRS80 +datum=NAD83 +units=m
I added +inv:
+inv
and inserted a custom spatial_ref_sys entry with a new SRID. I call the
transform:
select transform(my_evil_geom, 666) from geotest1;
and get this back from postgres:
SRID=666;MULTIPOLYGON(((232250.000000001 903426.499999985,232259
903417.499999987,232249.5 903409.999999986,232241.000000001
903418.999999986,232250.000000001 903426.499999985)))
(which is the state plane meters data I started with.)
Am I supposed to alter the units or something?
On Sun, 21 Dec 2003 15:30:31 -0800, Dave Blasby <dblasby at refractions.net>
wrote:
> Quoting Tony <doppelganger at doppelganger.org>:
>> Is there some way to do the equivalent of invproj?
>> Do I need to build my own special spatial_ref_sys entry?
> yes - you need to add rows to the spatial_ref_sys table.  Make sure you
> fill out the SRID and PROJ_TEXT columns.
> The actual transform is fairly easy:
> 1. make sure you have SRID entries in spatial_ref_sys for the lat/long
> projection and your stateplane
> 2. make sure your geometries have the correct srid (ie. your stateplane)
> 3. do a query like:
> SELECT tranform(the_geom, <lat long srid>) FROM table;
> dave
> postgis-users mailing list
