[postgis-users] shp2pgsql segmentation error
strk
strk at freek.keybit.net
Mon Feb 3 06:37:41 PST 2003
pramsey wrote:
> As always, an example shapefile will help us remove the bug.
> First, though: try the CVS version. There *have* been updates to
> shp2pgsql since the last release, and your bug may have been squashed
> already. If that fails, send us the example shapefile.
> P.
I've seen CVS version still contains the PIP bug in shp2pgsql.
That might give the segfault
(referencing one POINT3D past the available once).
Try applying this patch to shp2pgsql.c:
http://cobalt.rmnet.it/~san/postgis/shp2pgsql.c-CVS-PIP.diff
> Robert W. Burgholzer wrote:
> >> I m encountering segmentation errors while using shp2pgsql on some
> >> particular shapefiles (which I can load without any problem with
> >> ESRIs ArcExplorer).
> > This has happened to me when there are blank fields in the input shapefile.
> > r.b.
> __
> | Paul Ramsey
> | Refractions Research
> | Email: pramsey at refractions.net
> | Phone: (250) 885-0632
> \_
> postgis-users mailing list
