[postgis-users] Compilation Error with PostGRE 7.3.1.1 / CygWin
christian.schuster at rsag.ch
Fri Jan 31 01:58:50 PST 2003
Hi Pablo,
I also had the same problem as you. I asume you tried to make PostGIS
0.7.3. I also was not able to make PostGIS 0.7.3. I then downloaded the
CVS version and used a different Makefile which I found in the forum. The
one from the CVS did not work for me. I attached you this Makefile. Just
replace the one in the CVS version and then should be able to make
POSTGIS.
What you also will need to do is to edit the file
/usr/src/postgresql-7.3.1-1/src/include/optimizer/cost.h
Change the line
extern double cpu_index_tuple_cost;
into
extern DLLIMPORT double cpu_index_tuple_cost;
Also do not forget to configure PostgreSQL before you make PostGIS.
I configured PostgreSQL like this
./configure --enable-multibyte --with-CXX --prefix=/usr
--sysconfdri=/etc --docdir=/usr/doc/postgresql-$version
Then make postgresql but do not install it
make
Now you should be able to make PostGIS
Good luck
Christian Schuster
Rudolf Schuster AG
Postfach 277
CH - 3000 Bern 11
http://www.rsag.ch
++41 31 348 05 30
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20030131/3cc9e215/attachment.html>
Type: application/octet-stream
Desc: not available
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20030131/3cc9e215/attachment.obj>
