[postgis-users] PostGIS Windows Installer under XP
Laurent Michel laurent.michel at geo12.com
Sat Jul 5 05:03:15 PDT 2003
Sorry for my previous mail, I forgot the
-U postgres -h localhost
options (I should have read more carefully your mail!)
> -----Original Message-----
> From: sdteffen at web.de [mailto:sdteffen at web.de]
> Sent: vendredi 4 juillet 2003 16:56
> To: PostGIS Users Discussion; Laurent Michel
> Subject: Re: [postgis-users] PostGIS Windows Installer under XP
> Hello Laurent,
> > I successfully launched the installer, but then, I could not connect
to
> > postgresql :
> > psql template0 (or dcmms or template1) did not work even with the -U
> > postgres option.
> > I got a message like "could not connect to socket PSQL 5432 / is
> > postmaster running allowing connections" ... whereas postmaster was
> > indeed running....
> Are you sure that this postmaster service was installed by the
installer?
> What was the command you used to try to connect?
> psql -U postgres -h localhost template1
> should work if it's the one from the installer..
> > I tried to modify poistgresql.conf (after having found that the
postgres
> > accound uses the "dcmms" password), but the problem remained.
> Yes, the windows account "postgres" uses the password dcmms - there
> is no password for the postgresql user "postgres". The installer  is
not
> modifying the standard postgresql.conf delivered by the cygwin
postgres
> package.
> > Before using dcmms installer, I tried to configure all by myself. I
set
> > ipc-dameon service and postmaster as described in the doc, but I
could
> > never have postmaster running : "could not launch the service due to
> > session error..."
> This might be the real problem: The whole process and a lot of things
can
> go wrong. If you have the chance to test the installer on a second XP
> system
> that never had Postgresql installed, it should go easily - we tested
it on
> two
> systems successfully and I think also Tyler Mitchell had success. The
> current
> installer version just has a problem to set up the sample database and
> load
> PostGIS - the installer doesn't call the script correctly. We'll
provide
> an
> updated installer shortly.
> You can try the delete-dcmms.sh script that comes with the installer
> sources.
> It will remove the postgresql installation done by the installer
(which is
> pretty close to the one in the Windows Installation Tips). If you are
> lucky,
> it might work for you. After this, a fresh installer run might
succeed.
> If you still have problems, please include the log files create by the
> installer in
> c:\cygwin\tmp
> they might allow to find out what went wrong during the installation.
> > When I try to compile PostGis I get an error like "ld could not find
> > lpostgres". Any clue ?
> When you are using the installer, there is no need to compile
> PostGIS.
> Steffen
