[postgis-users] points to polyline or polygon
Randy James
rjames57 at yahoo.com
Tue Jul 15 15:02:59 PDT 2003
Hi
Well seems like it could work.
I plan to use an autonumber to ensure the points are in the
order the user clicked on the screen.
Collect places them in the order it finds them i guess? If
so the autonumber should work?
Cheers
Randy
--- chodgson at refractions.net wrote:
> You definitely do NOT want to do this - the COLLECT()
> aggregate function
> doesn't gauarantee any sort of order in the points it has
> collected.
> Furthermore, a Multipoint object is not necessarily
> ordered (it will always
> list the points in the same order, but not by necessity,
> only because it is
> simplest).
> The best way to solve this problem is to select your list
> of points from the
> table (they will also need to have an "order" column in
> order to make sure they
> are made into a line in the correct order) and use PHP or
> your language of
> choice to build a new WKT string.
> HTH.
> Chris
> > This is an interesting question to me. If I understand
> correctly, you want
> > to "cast" a set of points into a linestring. Getting
> your list of points
> > should be as easy as:
> > SELECT COLLECT(the_geom) FROM mytable GROUP BY
> somefield.
> > But this returns the geometry as MULTIPOINT, which
> isn't really want you
> > want, but if you see the text representation, it does
> look like a
> > linestring:
> > SRID=-1;MULTIPOINT(596681.75 5830977.5,532989.625
> 5869892,547653.0625
> > 5808612,608081.1875 5799629)
> > So can anyone else give a pointer on taking the above
> output and casting it
> > into a linestring instead?
> > Tyler
> postgis-users mailing list
http://postgis.refractions.net/mailman/listinfo/postgis-users
__________________________________
Do you Yahoo!?
SBC Yahoo! DSL - Now only $29.95 per month!
http://sbc.yahoo.com
