[postgis-users] export/import
Paul Ramsey pramsey at refractions.net
Mon Jul 21 20:36:22 PDT 2003
There are two "importable" forms. One is the form you are quoting. The
other is the "canonical" form, the text form which maps directly to a
database object. It is what you get if you do a simple "select geom
from thetable", or a simple database dump. It will import just time.
Try using "pg_dump -t" to dump a table. It will be perfectly restorable.
Paul
On Monday, July 21, 2003, at 07:51 PM, John Hagstrand wrote:
> How do I export to a backup text file and then import it back in?  The
> only
> way I know to insert the geom column is like this
> "GeometryFromText('POINT(-122.66 45.54)', 4326)".  But I don't anyway
> to
> export it in that format.
> Thanks
> John
> postgis-users mailing list
      Paul Ramsey
      Refractions Research
      Email: pramsey at refractions.net
      Phone: (250) 885-0632
