[postgis-users] debug_level options?
Mike Leahy
mgleahy at hotmail.com
Thu Jun 5 16:00:29 PDT 2003
Hello all again.
I have what I hope is a fairly simple question.when I do a query on a
map using layers from a PostGIS database, string of results will scroll
by in the Postmaster command window. Most of it looks like super long
series of TARGETENTRY statements (below).
This is also followed by a series of NOTICE messages before the query
finishes. The whole thing overall is working fine, but it can sometimes
be a fairly lengthy wait if there are multiple layers and lots of small
polygons. I expect it would be significantly faster if I could have the
postmaster work in a quiet mode of some type, either with the window
hidden or by turning off message reporting. I experimented with passing
a debug_level parameter (-d 1) with the pg_ctl command (i.e., pg_ctl
start -o "-i -d 1"), but that didn't really change anything. Does
anybody have any suggestions?
BTW: We are volunteering for an NGO in Peru to build an education
information system based on spatial data, and have relatively little
access to any development support network. As a result, we have been
relying heavily on email discussion lists. We appreciate all of the
help that has been offered by the participants of this list.
Kind regards,
Mike
{ TARGETENTRY
:resdom
{ RESDOM
:resno 66
:restype 23
:restypmod -1
:resname a_gra07gm
:reskey 0
:reskeyop 0
:ressortgroupref 0
:resjunk false
:expr
{ VAR
:varno 1
:varattno 66
:vartype 23
:vartypmod -1
:varlevelsup 0
:varnoold 1
:varoattno 66
