[postgis-users] debug_level options?
Mike Leahy
mgleahy at fes.uwaterloo.ca
Thu Jun 5 16:08:50 PDT 2003
Okay...checked that file, and the debug_level there is 0 (out of a range
of 0 to 16). I think there must be another debug_level option somewhere
else that I need to change...but I haven't found it in that folder...
-----Original Message-----
From: postgis-users-bounces at postgis.refractions.net
[mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of Paul
Ramsey
Sent: June 5, 2003 6:06 PM
To: PostGIS Users Discussion
Subject: Re: [postgis-users] debug_level options?
If I recall correctly, you are using a precompiled binary. Check in the
postgresql.conf file and see if the debugging is cranked up in there to
some non-default value.
P.
Mike Leahy wrote:
> Hello all again.
> I have what I hope is a fairly simple question.when I do a query on a
> map using layers from a PostGIS database, string of results will
scroll
> by in the Postmaster command window. Most of it looks like super long
> series of TARGETENTRY statements (below).
> This is also followed by a series of NOTICE messages before the query
> finishes. The whole thing overall is working fine, but it can
sometimes
> be a fairly lengthy wait if there are multiple layers and lots of
small
> polygons. I expect it would be significantly faster if I could have
the
> postmaster work in a quiet mode of some type, either with the window
> hidden or by turning off message reporting. I experimented with
passing
> a debug_level parameter (-d 1) with the pg_ctl command (i.e., pg_ctl
> start -o "-i -d 1"), but that didn't really change anything. Does
> anybody have any suggestions?
> BTW: We are volunteering for an NGO in Peru to build an education
> information system based on spatial data, and have relatively little
> access to any development support network. As a result, we have been
> relying heavily on email discussion lists. We appreciate all of the
> help that has been offered by the participants of this list.
> Kind regards,
> Mike
> __________________________________________
> { TARGETENTRY
> :resdom
> { RESDOM
> :resno 66
> :restype 23
> :restypmod -1
> :resname a_gra07gm
> :reskey 0
> :reskeyop 0
> :ressortgroupref 0
> :resjunk false
> :expr
> { VAR
> :varno 1
> :varattno 66
> :vartype 23
> :vartypmod -1
> :varlevelsup 0
> :varnoold 1
> :varoattno 66
> postgis-users mailing list
__
| Paul Ramsey
| Refractions Research
| Email: pramsey at refractions.net
| Phone: (250) 885-0632
\_
