[postgis-users] RE: [BUGS] missing DLLIMPORT for cpu_index_tu ple_cost
Obe, Regina DND\MIS robe.dnd at ci.boston.ma.us
Wed Jun 11 08:55:07 PDT 2003
Did you try doing
make clean
to clear out all the old compiled object junk.
-----Original Message-----
From: Mike Leahy [mailto:mgleahy at fes.uwaterloo.ca]
Sent: Wednesday, June 11, 2003 11:15 AM
To: nhv at cape.com; 'PostGIS Users Discussion'
Subject: RE: [postgis-users] RE: [BUGS] missing DLLIMPORT for
cpu_index_tuple_cost
Bruce/Group:
Just a question - how did you get this to work?  I tried this fix, and
got exactly the same error when I compiled - and nobody has been able to
suggest exactly where I've gone wrong.  I've been working with a beta of
PostGIS, and was hoping to build the latest version, but no luck.  I
can't seem to find up-to-date binaries anywhere either...
Are there some settings I need to reset before I retry compiling, or
does the DLLIMPORT command need to be used for more than one line in the
cost.h file?
Kind regards,
Mike
From: postgis-users-bounces at postgis.refractions.net
[mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of
Norman Vine
Sent: June 11, 2003 10:11 AM
To: Bruce Momjian
Cc: PostGIS Users Discussion
Subject: [postgis-users] RE: [BUGS] missing DLLIMPORT for
Thank You !!!
> From: Bruce Momjian [mailto:pgman at candle.pha.pa.us]
> Sent: Wednesday, June 11, 2003 11:01 AM
> To: nhv at cape.com
> Cc: pgsql-bugs at postgresql.org
> Subject: Re: [BUGS] missing DLLIMPORT for cpu_index_tuple_cost
> Patch applied.  Thanks.
> Norman Vine wrote:
> > add missing DLLIMPORT for cpu_index_tuple_cost to
> > src/include/optimizer/cost.h.
> > This is required to compile the PostGIS extension module
> > with Cygwin
> > http://postgis.refractions.net
> > Norman
> [ Attachment, skipping... ]
> > ---------------------------(end of
broadcast)---------------------------
> > TIP 4: Don't 'kill -9' the postmaster
>   Bruce Momjian                        |  http://candle.pha.pa.us
>   pgman at candle.pha.pa.us               |  (610) 359-1001
>   +  If your life is a hard drive,     |  13 Roberts Road
>   +  Christ can be your backup.        |  Newtown Square,
> Pennsylvania 19073
postgis-users mailing list
postgis-users at postgis.refractions.net
http://postgis.refractions.net/mailman/listinfo/postgis-users
