[postgis-users] Performance tuning PostGIS and understanding the explain statement
David Blasby
dblasby at refractions.net
Thu Jun 12 16:43:47 PDT 2003
The difference between 'EXPLAIN' and 'EXPLAIN ANALYSE' is simple -
'EXPLAIN ANALYSE' actually does the query and reports the actual time it
takes to do each step.
So "actual" time is in millisecond, and the other times are estimated
times in some arbitrary units. Postgresql uses these estimated times to
determine which is the best query plan to excecute.
A brief look at your query seems to indicate that postgresql is using
the spatial index over the attribute index (region.id=28). If you use
the PostGIS stats package (search the mailing list for histogram2d) you
will probably find it estimates a better plan.
You can also try dropping the spatial index and see what you get.
The problem is that you are doing a full spatial join of the region and
feature tables.
dave
