[postgis-users] PostGIS 0.7.5 returning '0' for shape indexes
Paul Ramsey pramsey at refractions.net
Fri Jun 13 09:49:08 PDT 2003
This is a bug which has been reported before, but we have not looked at
it seriously. It would be good if someone could make it easy for us by
giving us a sample data table and a sample PHP script which reduce the
problem to its bare minimum.
Thanks,
Paul
Mike Leahy wrote:
> Now that I have PostGIS 0.7.5 running in the Cygwin environment, the
> GMapFactory project I am using is able to display the layers that I have
> loaded into the database without any trouble.  However, when I query the
> layers, I get the following error from the PHP script:
> Fatal error: Assertion failed, Could not set shape values: 0, 0 in
> C:\edumap\www\Independencia\wrapper\map_query.php on line 530
> Line 530 in this case is labelled below, in the processQuery function.
> I think the problem here is that for some reason the query is returning
> a bunch of shapes with 0 or null spatial index.  I tried making an if
> statement that skips the code in the loop if the spatial index is not
> greater than zero, and I just ended up with some other error (i.e.,
> there were no results to be displayed).
> I'm not sure if this is a problem with the GMapFactory project,
> MapScript, or PostGIS.  It seems that for the time being, I'm going to
> have to stick with the beta version of PostGIS.  I tried creating
> indexes on the GID fields for the spatial tables, but that doesn't seem
> to have any affect.
> Any suggestions for this one?
> Many thanks,
> Mike
> ________________________________________________________________________
> ____
> function processQuery( $oLayer )
>         // log entry
>         $this->logFuncStart( LOG_VERBOSE, "processQuery() starting" );
> 		// create map object
> 		$oMap = $this->oSession->oMap;
> 		// initialize variables
> 		$axResults = array();
>     	// get the number of results
>     	$nNumResults = intval($oLayer->getNumResults());
> 		// return if no results
> 		if ( $nNumResults < 1 )
>           	// log exit
>             $this->logFuncEnd( LOG_ALL, "processQuery() done" );
> 			return "No results found for
> layer[".$oLayer->name."].";
> 		// open the layer to make the shape properties available
> 		if ( strpos( strtoupper( ms_GetVersion() ), "VERSION
> 3.6") > 0 )
>     		$oLayer->open( $oMap->shapepath );
>     	else
>     		$oLayer->open();
>     	// add element to results array for each result row
> 	    for ($i=0; $i < $nNumResults; $i++)
>             // get next shape row
>             $oResult = $oLayer->getResult($i);
>  Line 530:  $oShape = $oLayer->getShape($oResult->tileindex,
> $oResult->shapeindex);
>             // push the row array onto the results array
>             $aTmp = $oShape->values;
>             $aTmp = array_merge( $aTmp ,
>                 array("SHAPE_INDEX" => $oResult->shapeindex,
>                       "TILE_INDEX" => $oResult->tileindex,
>                       "LAYER_INDEX" => $oLayer->index ) );
> 			array_push( $axResults, $aTmp );
> 		// end for loop
>         // close the layer
>         $oLayer->close();
> 				$this->log( LOG_VERBOSE, "Results:
> ".implode($axResults));
>       	// log exit
> 		// return the array
> 		return $axResults;
> 	// end processQuery function
> postgis-users mailing list
       __
      | Paul Ramsey
      | Refractions Research
      | Email: pramsey at refractions.net
      | Phone: (250) 885-0632
      \_
