[postgis-users] PostGIS 0.7.5 returning '0' for shape indexes
Mike Leahy
mgleahy at fes.uwaterloo.ca
Fri Jun 13 10:51:33 PDT 2003
I don't think the issue is that the features have no attributes - I know
full well that they do, and the exact same tables have no problems if I
use the PostGIS binaries (Multera's build) from Tyler Mitchell.
There is a post at
http://mapserver.gis.umn.edu/data2/wilma/mapserver-users/0207/msg00537.h
tml that indicates this problem can be solved by commenting out a line
in mapquery.c - and the example in the buglist is pretty much the same
problem I have...but considering the trouble I've gone through just to
compile postgis, I don't think would be very successful at compiling
mapserver w MapScript/PostGIS support.
Mike
-----Original Message-----
From: postgis-users-bounces at postgis.refractions.net
[mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of
David Blasby
Sent: June 13, 2003 12:02 PM
To: PostGIS Users Discussion
Subject: Re: [postgis-users] PostGIS 0.7.5 returning '0' for shape
indexes
Mike Leahy wrote:
> Fatal error: Assertion failed, Could not set shape values: 0, 0 in
> C:\edumap\www\Independencia\wrapper\map_query.php on line 530
I believe this is going to be fixed by the mapserver folks. Its bug
#316 in their bugzilla.
In summary, mapserver doesnt like feature's without attributes.
dave
postgis-users mailing list
postgis-users at postgis.refractions.net
http://postgis.refractions.net/mailman/listinfo/postgis-users
