[postgis-users] Postgis Transform Problem
Benjamin Wragg
bwragg at tpg.com.au
Tue Jun 24 22:35:43 PDT 2003
I'm having a problem with the transform function in Postgis. If I run
the following query:
select transform(GeometryFromText('MULTIPOLYGON(((112 -45 ,112 -10 ,155
-10 ,155 -45,112 -45)))',4326),54004)
I get:
SRID=54004;MULTIPOLYGON(((12467782.9688466
-5591295.91855339,12467782.9688466 -1111475.10285223,17254521.0729574
-1111475.10285223,17254521.0729574 -5591295.91855339,12467782.9688466
-5591295.91855339)))
But if I do:
select transform(GeometryFromText('MULTIPOLYGON(((-180 -90 ,-180 90 ,180
90 ,180 -90,-180 -90)))',4326),54004)
I get:
Error: transform: couldn't project polygon
Warning: Error occurred while executing PL/pgSQL function transform
Warning: line 2 at return
Any ideas why? I turned the postgresql log level to debug5 to see if I
could get more detailed errors, but it's exactly the same error. I'm
running postgresql 7.3.2, postgis 0.7.5 and proj 4.4.7
Thanks,
Benjamin Wragg
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20030625/bf1e22b3/attachment.html>
