[postgis-users] psql2shp on two tables to get one shapefile...
Paul Ramsey
pramsey at refractions.net
Wed Jun 25 13:24:59 PDT 2003
Yes, a temporary table (look up variants of SELECT INTO and INSERT)
should work fine. A view might also work, but I do not know that for
certain. Jeff?
P.
Nick Ton wrote:
> Hi Everyone,
> I am trying to create a shapefile where the data is based on two different
> tables.
> Has anyone done this before? Here is my problem, simplified:
> -- City table contains some information, plus the_geom
> CREATE TABLE city_tbl
> city_id int,
> name text,
> area_cvrg real,
> the_geom geometry,
> PRIMARY KEY (city_id)
> -- City statistics table contains additional information
> -- that has to be linked to the city table in order to make the shapefile
> complete
> CREATE TABLE city_stats_tbl
> budget numeric,
> population real,
> city_id REFERENCES city_tbl
> One thought I had but wasn't sure if this is correct -- could I join the two
> tables
> together into a temp table, then perform a pgsql2shp on the temp table.
> Please let
> me your thoughts.
> Thanks,
> Nick
> postgis-users mailing list
__
| Paul Ramsey
| Refractions Research
| Email: pramsey at refractions.net
| Phone: (250) 885-0632
\_
