[postgis-users] Re: [Mapserver-users] Query postgis layer
Christian Blumer christian.blumer at epfl.ch
Fri Jun 27 07:33:21 PDT 2003
Oups I forgot that,
I perform
    $map->queryByPoint($clickGeo, MS_SINGLE, -1);
Christian Blumer
Ecole Polytechnique Fédérale de Lausanne
ENAC/INTER/PHOT
Batiment GR
1015 Lausanne, Switzerland
  ----- Original Message -----
  To: postgis-users at postgis.refractions.net
  Sent: Friday, June 27, 2003 4:19 PM
  Subject: [postgis-users] Re: [Mapserver-users] Query postgis layer
  Christian,
  where do you perform de query in the mapscript script???
  >I am using
  >$my_layer = $map->getlayerbyname(ptmesure);
  Here you must include something like
  $my_layer->queryByPoint($my_point,MS_MULTIPLE,0)
  OR
  $my_layer->queryByRect($my_rect)
  >$numResults = $my_layer->getNumResults();
  >but the query result is always 0.
  Regards
  Oscar
    Cc: mapserver-users at lists.gis.umn.edu
    Sent: Friday, June 27, 2003 10:10 AM
    Subject: [Mapserver-users] Query postgis layer
    Hi all
    I would like to make a query on a layer connected to postgis with PHP mapscript.
    The layer definition is:
    LAYER
      NAME ptmesure
      STATUS off
      TYPE POINT
      CONNECTIONTYPE postgis
      CONNECTION "user=xxx password=xxx dbname=test host=xxx"
      DATA "the_geom from (select * from mesure) as foo using unique gid using SRID=-1"
      CLASS
        NAME "gps"
        COLOR 220 0 0
        SYMBOL 'circle'
        SIZE 7
        TEMPLATE "mesure.html"
      END
      HEADER "mesure_header.html"
      FOOTER "mesure_footer.html"
      TOLERANCE 10
    END
    I am using
    I tested is on the same layer but in shape format and it worked.
    What should I do to make it work properly on a postgis layer?
    Cheers,
    Christian
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20030627/f9eb9c53/attachment.html>
