[postgis-users] Postgis Transform Problem
Benjamin Wragg bwragg at tpg.com.au
Mon Jun 30 22:43:46 PDT 2003
I tried the cs2cs utility. I think I'm passing the correct paramaters.
If I enter the following:
	cs2cs +proj=latlong +ellps=WGS84 +to +proj=merc +lon_0=150.0
	180 90
I get
	*	* 0.00
If I type any other coordinate I get a figure back. So is the cs2cs
utility what Postgis uses to project it's coords? If it does, it seems
this is whats causing the problem.
Thanks,
Benjamin
-----Original Message-----
From: postgis-users-bounces at postgis.refractions.net
[mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of Paul
Ramsey
Sent: Wednesday, 25 June 2003 10:55 PM
To: bwragg at tpg.com.au; PostGIS Users Discussion
Subject: Re: [postgis-users] Postgis Transform Problem
Those coordinates are right on the edge of the global plane, could be
hitting the edge of validity in the reprojection library. Try testing
the same stuff directly using the proj4 cs2cs utility.
On Tuesday, June 24, 2003, at 10:35 PM, Benjamin Wragg wrote:
> I'm having a problem with the transform function in Postgis. If I run
> the following query:
> select transform(GeometryFromText('MULTIPOLYGON(((112 -45 ,112 -10
> ,155 -10 ,155 -45,112 -45)))',4326),54004)
> I get:
> SRID=54004;MULTIPOLYGON(((12467782.9688466
> -5591295.91855339,12467782.9688466 -1111475.10285223,17254521.0729574
> -1111475.10285223,17254521.0729574 -5591295.91855339,12467782.9688466
> -5591295.91855339)))
> But if I do:
> select transform(GeometryFromText('MULTIPOLYGON(((-180 -90 ,-180 90
> ,180 90 ,180 -90,-180 -90)))',4326),54004)
> I get:
> Error: transform: couldn't project polygon
> Warning: Error occurred while executing PL/pgSQL function transform
> Warning: line 2 at return
> Any ideas why? I turned the postgresql log level to debug5 to see if I
> could get more detailed errors, but it's exactly the same error. I'm
> running postgresql 7.3.2, postgis 0.7.5 and proj 4.4.7
> Thanks,
> Benjamin Wragg
      Paul Ramsey
      Refractions Research
      Email: pramsey at refractions.net
      Phone: (250) 885-0632
postgis-users mailing list postgis-users at postgis.refractions.net
http://postgis.refractions.net/mailman/listinfo/postgis-users
