[postgis-users] PointM, PolyLineM, PolygonM
strk
strk at freek.keybit.net
Tue Mar 4 09:36:05 PST 2003
pramsey wrote:
> Is is possible to have measure *and* elevation in a shapefile? XYZM? Or
> is it only XYZ and XYM?
> Paul
I think it is *NOT* possible.
>From the Shapefile Format Specification this is the list of known shapes:
Value Shape Type
0 Null Shape
1 Point
3 PolyLine
5 Polygon
8 MultiPoint
11 PointZ
13 PolyLineZ
15 PolygonZ
18 MultiPointZ
21 PointM
23 PolyLineM
25 PolygonM
28 MultiPointM
31 MultiPatch
I think using the Z field could be ok, but we need a function that tell
us wheater a geometry is 2d,3d or measured. Does OGC say anything about
measures ? The array option might also work as a temporary solution, as
would do a just-drop-measure approach.
... shp2pgsql could give a few options (--measured-policy=[array|discard])
--strk;
> Frank Warmerdam wrote:
> > Paul Ramsey wrote:
> >> Since the measures are a vertex-by-vertex measurement, not a
> >> feature-by-feature one, they cannot be dropped into an attribute
> >> table, generally speaking.
> > Paul,
> > But they could be kept in an "array" field, couldn't they? I realize
> > this would lose the explicit relationship with the geometry and it
> > might get out of sync if operations were done, but it seems like a
> > cheap way to incorporate the data now. The loader could give an
> > option to do this, or to insert as the Z coordinate in the geometry.
> > Best regards,
> __
> | Paul Ramsey
> | Refractions Research
> | Email: pramsey at refractions.net
> | Phone: (250) 885-0632
> \_
> postgis-users mailing list
