[postgis-users] Error with ~ and @ operators and GIST indexes?
Michael O'Sullivan
mos at i3sp.com
Wed Mar 5 23:11:02 PST 2003
Hi all,
I seem to have crossed a bug that was discussed on the list a while back
trying to use the ~ and @ operators on GIST geometry based indexes.
Firstly, reading the doco for the ~ operator it states
A ~ B
The "~" operator returns true of A's bounding box is completely
contained by B's bounding box.
However I see the opposite results
e.g.
A = BOX 11 11, 14 14
B = BOX 10 10, 15 15
A is definitely contained by B.
newnavitag=# select GeometryFromText('BOX3D(11 11, 14 14)',-1) ~
GeometryFromText('BOX3D(10 10, 15 15)',-1) as contained;
contained
f
(1 row)
newnavitag=# select GeometryFromText('BOX3D(10 10, 15 15)',-1) ~
GeometryFromText('BOX3D(11 11, 14 14)',-1) as contained;
contained
t
swapping ~ for @ gives the expected results
newnavitag=# select GeometryFromText('BOX3D(11 11, 14 14)',-1) @
contained
t
(1 row)
Reading postgis.sql I see that
@ calls procedure geometry_contained
and
~ calls procedure geometry_contain.
I have assumed a typo and have moved on to using @ in place of ~ the
operator.
Now I have come to creating and using GIST indexes and I see the query
on my dataset returning different results depending on whether I have
the data indexed (gist) or not.
Reading a post in the list from a while back I see that there was a
problem with postgis and postgres mixing the ~ and @ (contains and
contained) operators. I thought this would explain the doco error and my
data error.
I now find that the @ operator seems to do what the ~ is documented to
do, however it still gives different data based on whether there is a
GIST index on the geometries or not.
e.g.
newnavitag=# select name from geo_locations where the_geom @
GeometryFromText('BOX3D(150.0 -35.0, 152.0 -32.0 )', 4269);
name
NEWCASTLE
SYDNEY
(2 rows)
newnavitag=# create INDEX geo_locations_gist_idx ON geo_locations USING
GIST( the_geom GIST_GEOMETRY_OPS );
CREATE INDEX
name
(0 rows)
newnavitag=# \d geo_locations
Table "public.geo_locations"
Column | Type | Modifiers
gid | integer | not null
name | character varying(64) |
country | character varying(96) |
type | character varying(32) |
radius | integer |
external_id | integer |
the_geom | geometry |
Indexes: geo_locations_pkey primary key btree (gid),
geo_locations_gist_idx gist (the_geom)
Check constraints: "$1" (srid(the_geom) = 4269)
"$2" ((geometrytype(the_geom) = 'POINT'::text) OR
(the_geom IS NULL))
My data is a set of POINT geometries in lat long.
I have tried reversing the arguments and using the ~ operator and I get
the same results. When I perform the query with an index, I do not get
the same results as when I have no ndex.
any ideas?
thanks,
Michael
Michael O'Sullivan <mos at i3sp.com>
"A good man always knows his limitations" - HC
