[postgis-users] Is there a Java API for PostGIS
rhranac at openplans.org
Thu Mar 13 10:54:38 PST 2003
We wrote much of the original GeoTools PostGIS API, which does fully
handle both importing to and exporting from the PostGIS database.
GeoTools is big, but quite modular, so you could fairly effectively just
use the PostGIS module for importing and exporting, if you wish. I
suggest that you get in directly touch with chris.holmes at openplans.org
or myself if you want more details. Or you can show up at the weekly
GeoTools developer IRCs (see website).
Best Regards,
Rob Hranac
Quoting Paul Ramsey <pramsey at refractions.net>:
> If you're hell bent on using someone else's API to manipulate the
> database why not check out the GeoTools (www.geotools.org) PostGIS
> data
> sources, which should do both reads and writes. Failing that,
> construct your own SQL INSERT statement and stuff it through JDBC.
> Paul
> On Thursday, March 13, 2003, at 04:23 AM, christian.schuster at rsag.ch
> wrote:
> > This could help in some way. But I do not just need to get data
> from a
> > PostGIS database. I also will need to insert them into PostGIS. To
> > create a
> > geographic object is not the big problme because I just have point,
> > line,
> > ellipse and polygon. The probleme is that these geographic objects
> are
> > coming from an applet to a servlet on the server which needs to
> make a
> > connection to another server (WebServer and DataServer are split
> and
> > not at
> > the same location) where the PostGIS database is located. Also
> speed
> > is not
> > that big issue due small data amount.
> > So, if anyone has ideas let me know please.
> postgis-users mailing list
