[postgis-users] Spatial Ref Sys oops
Carl Anderson
carl.anderson at vadose.org
Sat Mar 15 09:43:39 PST 2003
I have been have some problems using transform(geometry,srid)
I tracked it down to an oops in the spatial_ref_sys file
For SRID's that are in coordinate units other than meters this is
true. SRID's tha are in meters are not affected by this.
using SRID 102667 -- NAD83 Georgia West (FIPS 1002) US Feet as an
example
The srtext field shows the false easting in meters not in feet (the
projections coord units).
Additionally proj4 needs a units parameter otherwise it will not change
coordinate units.
initially
select transform('SRID=102667;POINT(2284248.581058
314340.180605)'::geometry,4267);
transform
SRID=4267;POINT(-100.609237649977 29.8157860269902)
wrong location
fixing the proj4text from
+proj=tmerc +lat_0=30.000000000 +lon_0=-84.166666667 +k=0.999900
+x_0=2296583.333 +y_0=0.000 +ellps=GRS80 +to_meter=+0.3048006096
BY (for grins throw a proj4.4.5 datum also)
update spatial_ref_sys set proj4text = '+proj=tmerc +lat_0=30.000000000
+lon_0=-84.166666667 +k=0.999900 +x_0=700000.00 +y_0=0.000 +ellps=GRS80
+units=us-ft +datum=NAD83' where srid = 102667;
then produces the correct results
transform
SRID=4267;POINT(-84.2060804142583 30.864143821645)
C.
