[postgis-users] error executing postgis.sql
Jaakko Kähkönen
jaakko.kahkonen at fgi.fi
Wed Mar 19 00:10:46 PST 2003
Heiko.Kehlenbrink at vermes.fh-oldenburg.de wrote:
> trying postgis 0.7.4 i got :
> BEGIN
> message
> PL/PgSQL is installed.
> (1 row)
> psql:postgis.sql:18: NOTICE: ProcedureCreate: type histogram2d is not yet defined
> psql:postgis.sql:18: ERROR: stat failed on file '$libdir/libpostgis.so.0.7': No such file or
> directory
I got this also with Gentoo linux on Sparc64 (postgresql 7.3, postgis 0.7.4)
In my case I changed all '$libdir/libpostgis.so.0.7' to
'/usr/lib/libpostgis.so.0.7' in postgis.sql file.
Also "createlang plpgsql [yourdatabase]" made some mistakes with path to
plpgsql.so, so I made it "manually" in psql prompt
CREATE FUNCTION plpgsql_call_handler() RETURNS OPAQUE AS
'/usr/lib/postgresql/plpgsql.so' LANGUAGE 'C';
CREATE TRUSTED PROCEDURAL LANGUAGE 'plpgsql' HANDLER
plpgsql_call_handler LANCOMPILER 'PL/pgSQL';
before "psql -d [yourdatabase] -f postgis.sql".
Now Postgis seems to be working ok. Hopefully somebody knows the origin
of the "$libdir" problem...
regards,
Jaakko
