[postgis-users] Building Postgres under FreeBSD 4.7
Paul Ramsey
pramsey at refractions.net
Mon Mar 24 07:41:16 PST 2003
It sounds like your version of make does not like our makefile for some
reason. Try 'gmake' first and see what happens.
Paul
On Sunday, March 23, 2003, at 10:09 AM, Benjamin Thelen wrote:
> Hi,
> I am quite new to Unix and started with FreeBSD 4.7. I've installed
> postgresql 7.2.2 via the ports collection and it is running.
> Additionally I downloaded the postgresql source tree, built it
> (/.configure, make) and added the postgis source code into
> postgresql/contrib./postgis After that I compiled the proj4 library
> without problems. Then I tried to compile postgis 0.7.2, but the
> process
> stops with an error message like you find below. I then deleted the
> 0.7.2 Code and took 0.7.4. The message between 0.7.2 and 0.7.4 differs
> a
> little but both are telling something about missing dependency operator
> and so on.
> bsd# cd /root/tmp/postgresql-7.2.2/postgresql-7.2.2/contrib/postgis/
> bsd# make
> "/root/tmp/postgresql-7.2.2/postgresql-7.2.2/contrib/postgis/Makefile",
> line 25:
> Missing dependency operator
> line 29:
> Need an operator
> line 33:
> Need an operator
> Error expanding embedded variable.
> I read a thread in the postgis mailing list about FreeBSD and postgis
> but it doesn't help very much, because there is just one thing
> mentioned
> what must be changed (add "include "machine/endian.h"" to
> postgis_debug.c), but the rest of the necessary changes are not
> mentioned at all. He also says it is difficult for a novice to compile
> postgis.
> Here are the first lines of the postgis 0.7.4 Makefile, where I've
> changed the USE_PROJ to 1.
> Configuration Directives
> # Set USE_PROJ to 1 for Proj4 reprojection support
> USE_PROJ=1
> PROJ_DIR=/usr/local
> # Set USE_STATS to 1 for new GiST statistics collection support
> # Note that this support requires additional columns in
> # GEOMETRY_COLUMNS, so see the list archives for info or
> # install a fresh database using postgis.sql
> USE_STATS=0
> subdir=contrib/postgis
> What can I do to have it running? I would think it is something what
> must be changed in the Makefile, but I guess I am wrong. I don't know
> where to start my error search. Is it easier to take Linux?
> Thanks in advance,
> Benjamin
> postgis-users mailing list
Paul Ramsey
Refractions Research
Email: pramsey at refractions.net
Phone: (250) 885-0632
