[postgis-users] Which Version of postgresql/postgis
Paul Ramsey
pramsey at refractions.net
Mon Mar 24 10:48:07 PST 2003
I would encourage you to keep on working with 7.3 unless things truly
become impossible. While schemas were a major 7.3 enhancement, there
were other enhancements as well which are worth keeping with 7.3 on. At
a minimum, when you go to upgrade to 7.4 in 6 months, the amount of
changes relative to your current version will be reduced :)
P.
Benjamin Thelen wrote:
> another question and thanks to all for your help!
> I am not sure whether I can use PostgreSQL 7.3.x with postgis. It is
> said on the homepage, that " Version 7.3.X of PostgreSQL is now
> supported, although explicit support for "schemas" has not been added
> yet", but I found in some postings, that it could be better to use
> PostgreSQL 7.2.x. I don't know what schemas are. Do I need schemas?
> I would use, just to be sure to do the right thing, PostgreSQL 7.2.4
> with Postgis 0.7.4. But if it is ok, I would install PostgreSQL 7.3.x.
> So what should I install?
> Thanks in Advance
> Benjamin
> postgis-users mailing list
__
| Paul Ramsey
| Refractions Research
| Email: pramsey at refractions.net
| Phone: (250) 885-0632
\_
