[postgis-users] Undefined references
Paul Ramsey
pramsey at refractions.net
Tue Mar 25 07:02:04 PST 2003
Are you sure that the backslash is the right thing? I thought Cygwin
provided a complete UNIX shell, so the thing to do would be to replace
libdir with /lib ?
On Tuesday, March 25, 2003, at 06:59 AM, Nicolas RIBOT wrote:
> Hello Marc-Andre,
> Try replacing '$libdir/postgis.dll' by the full Windows path to
> postgis.dll (something like c:\cygwin\urs\src...\postgis.dll) in your
> postgis.sql file.
> I'm not sure if system variables, like $libdir, are correctly handled
> when running scripts.
> I had many errors with this too on my cygwin installation: I was not
> able to put as system variable in this script to point to the
> postgis.dll folder.
> It is also possible that you have to escape the '\' character.
> (c:\\cygwin\\... for example).
> I hope this helps.
> Nicolas Ribot
>> Paul,
>> Thanks! I have been able to install PostGIS!!!
>> But now, I would like to buid a layer in PostGIS and view it
>> from Mapserver...
>> I have still created my DB and the createlang command worked
>> correctly.
>> However, here is what I get when I call the following command:
>> $ psql -U postgres -d myGISdb -f postgis.sql
>> BEGIN
>> message
>> PL/PgSQL is installed.
>> (1 row)
>> NOTICE: ProcedureCreate: type histogram2d is not yet defined
>> psql:postgis.sql:18: NOTICE: ProcedureCreate: type
>> ed
>> ERROR: stat failed on file '$libdir/postgis.dll': No such
>> file or directory
>> psql:postgis.sql:18: ERROR: stat failed on file
>> file or directory
>> ERROR: current transaction is aborted, queries ignored until
>> end of transaction
>> block
> postgis-users mailing list
Paul Ramsey
Refractions Research
Email: pramsey at refractions.net
Phone: (250) 885-0632
