[postgis-users] Undefined references
Vincent Schut schut at sarvision.com
Tue Mar 25 06:59:11 PST 2003
Marc-André,
If I remember well this was on the list before and the working solution (or
actually work-around) was to edit the sql file and replace all $libdir/ with
the dir the lib is in, e.g. '/lib/'.
Regards,
Vincent Schut.
On Tuesday 25 March 2003 15:37, Marc-André Morin wrote:
> Paul,
> Thanks!  I have been able to install PostGIS!!!
> But now, I would like to buid a layer in PostGIS and view it from
> Mapserver... I have still created my DB and the createlang command worked
> correctly. However, here is what I get when I call the following command:
> $ psql -U postgres -d myGISdb -f postgis.sql
> BEGIN
>         message
>  PL/PgSQL is installed.
> (1 row)
> NOTICE:  ProcedureCreate: type histogram2d is not yet defined
> psql:postgis.sql:18: NOTICE:  ProcedureCreate: type histogram2d is not yet
> defin ed
> ERROR:  stat failed on file '$libdir/postgis.dll': No such file or
> directory psql:postgis.sql:18: ERROR:  stat failed on file
> '$libdir/postgis.dll': No such file or directory
> ERROR:  current transaction is aborted, queries ignored until end of
> transaction block
> That's strange, because the dynamic library postgis.dll can be found in the
> /lib/ directory...
> Any ideas about this error?  I checked in postgis archive list and I found
> nothing...
> thanks in advance,
> Marc-Andre
> ----- Original Message -----
> From: Paul Ramsey <pramsey at refractions.net>
> Date: Mon, 24 Mar 2003 11:14:52 -0800
> To: PostGIS Users Discussion <postgis-users at postgis.refractions.net>
> Subject: Re: [postgis-users] Undefined references
> > I thought your problem sounded familiar. It looks like the cygwin
> > compile requires that the static pgsql libraries be referenced during
> > the linking phase of postgis. Anyhow, the end of the relevant thread is
> > referenced here:
> > http://postgis.refractions.net/pipermail/postgis-users/2003-February/0021
> >28.html
> > Paul
> > > Yes, I followed instructions from your Windows install guide.
> > > And as mentionned, I installed cygwin (binaries) and PostgreSQL.  For
> > > postgresql, I downloaded sources and launched the ./configure and teh
> > > make functions. All as been done successfully...
> > > So, I put de package of PostGIS in the contrib directory of
> > > postgresql...  And when I launched the make function, I got these
> > > undefined references...
> > > What could I do?
> > > Date: Mon, 24 Mar 2003 10:23:55 -0800
> > >>Marc-Andr?,
> > >>   The CygWin install can be tricky, and the 7.3 install has been
> > >>noticably hard for people.  Have you followed the instructions from the
> > >>Windows install guide at http://www.gasai.com/gisapps/WindowsHowTo.html
> > >>?  I am not sure (Norman could confirm) whether or not installing
> > >>against a tarbal is preferable to installing against the cygwin src
> > >> package. Yours,
> > >>Paul
> > >>Marc-Andr? Morin wrote:
> > >>>Hi Kolks,
> > >>>I'm a newbie with PostGIS and I'm trying to set up it.
> > >>>Fist of all, I installed Cygwin 2.249.2.5 and configured PostgreSQL
> > >>> 7.3-2 (bin and src) on W2K.
> > >>>All work without errors.
> > >>>Now, I try to install PostGIS 0.7.4
> > >>>Here is what I got when I called make:
> > >>>$ make
> > >>>gcc -O2 -Wall -Wmissing-prototypes -Wmissing-declarations  -g -I.
> > >>> -I../../src/include  -DFRONTEND -DSYSCONFDIR='"/etc/postgresql"'
> > >>> -DUSE_VERSION=73  -c -o postgis_debug.o postgis_debug.c gcc -O2 -Wall
> > >>> -DUSE_VERSION=73  -c -o postgis_ops.o postgis_ops.c gcc -O2 -Wall
> > >>> -DUSE_VERSION=73  -c -o postgis_fn.o postgis_fn.c gcc -O2 -Wall
> > >>> -DUSE_VERSION=73  -c -o postgis_inout.o postgis_inout.c gcc -O2 -Wall
> > >>> -DUSE_VERSION=73  -c -o postgis_proj.o postgis_proj.c gcc -O2 -Wall
> > >>> -DUSE_VERSION=73  -c -o postgis_chip.o postgis_chip.c gcc -O2 -Wall
> > >>> -DUSE_VERSION=73  -c -o postgis_transform.o postgis_transform.c
> > >>> postgis_transform.c: In function `transform_geom':
> > >>>postgis_transform.c:437: warning: control reaches end of non-void
> > >>> function gcc -O2 -Wall -Wmissing-prototypes -Wmissing-declarations
> > >>> -g -I. -I../../src/in clude  -DFRONTEND
> > >>> -DSYSCONFDIR='"/etc/postgresql"' -DUSE_VERSION=73  -c -o postg
> > >>> is_gist_72.o postgis_gist_72.c
> > >>> -I../../src/in clude  -DFRONTEND -DSYSCONFDIR='"/etc/postgresql"'
> > >>> -DUSE_VERSION=73  -c -o postg is_estimate.o postgis_estimate.c
> > >>>dlltool --export-all --output-def postgis.def postgis_debug.o
> > >>> postgis_ops.o post gis_fn.o postgis_inout.o postgis_proj.o
> > >>> postgis_chip.o postgis_transform.o postg is_gist_72.o
> > >>> postgis_estimate.o
> > >>>dllwrap -o postgis.dll --dllname postgis.dll --def postgis.def
> > >>> postgis_debug.o p ostgis_ops.o postgis_fn.o postgis_inout.o
> > >>> postgis_proj.o postgis_chip.o postgis_ transform.o postgis_gist_72.o
> > >>> postgis_estimate.o ../../src/utils/dllinit.o -L/us r/local/lib
> > >>> -L/usr/local/lib
> > >>>postgis_debug.o(.text+0x2e0): In function `mem_size':
> > >>>/cygdrive/c/postgresql/contrib/postgis-0.7.4/postgis_debug.c:101:
> > >>> undefined refe stgis_estimate.c:743: undefined reference to
> > >>> `_make_ands_explicit'
> > >>> postgis_estimate.o(.text+0x1398):/cygdrive/c/postgresql/contrib/postg
> > >>>is-0.7.4/po stgis_estimate.c:745: undefined reference to
> > >>> `_canonicalize_qual' collect2: ld returned 1 exit status
> > >>>dllwrap: gcc exited with status 1
> > >>>make: *** [libpostgis.a] Error 1
> > >>>Does anybody could help me?
> > >>>Best regards,
> > >>>Marc-Andre
> > >>       __
> > >>      | Paul Ramsey
> > >>      | Refractions Research
> > >>      | Email: pramsey at refractions.net
> > >>      | Phone: (250) 885-0632
> > >>      \_
> > >>_______________________________________________
> > >>postgis-users mailing list
> > >>http://postgis.refractions.net/mailman/listinfo/postgis-users
> >        __
> >       | Paul Ramsey
> >       \_
Vincent Schut (schut at sarvision.com)
Sarvision B.V.
Wageningen, The Netherlands
www.sarvision.com
