[postgis-users] Nearest Operator
Michael O'Sullivan
mos at i3sp.com
Fri May 9 20:08:10 PDT 2003
> Dear all,
> Is PostGIS planned to include nearest operator? Just like SDO_NN
> operator in
> Oracle Spatial.
Try looking at the FAQ (http://postgis.refractions.net/docs/c191.html)
8. What is the best way to find all objects within a radius of another
object?
I use something like this to find the nearest point in the database to a
given point. I do a bounding box query as in the FAQ and then select the
minimum distance (calculated using length_spheroid) of the subset of
points to get the closest point to a given point. Depending on what your
data set is (e.g. a projected coordinate system or lat long) you may
want to use the distance function rather than length_spheriod.
My geometries are all Lat/Long based POINT objects (in this case).
hope this helps,
Michael
Michael O'Sullivan <mos at i3sp.com>
"A good man always knows his limitations" - HC
