[postgis-users] Please help - Value too long
David Blasby
dblasby at refractions.net
Mon May 12 12:02:45 PDT 2003
Oscar Testa wrote:
> SELECT
> nivel_imp::text,asbinary(force_collection(force_2d(the_geom)),'NDR'),OID::text
> from (select localidad_plano.oid as oid, localidad_plano.the_geom as
> the_geom, web_implem_grado.grado as nivel_imp from localidad_plano,
> inf_institucion, web_implem, web_implem_grado WHERE
> localidad_plano.codigopostal =
> bpchar(inf_institucion.codigo_postal,10) AND
> inf_institucion.id_institucion = web_implem.id_institucion AND
> web_implem.pampa = web_implem_grado.grado ) AS foo WHERE the_geom &&
> setSRID('BOX3D(-73.597264 -57.9529488695652,-53.562864
> -18.8021391304348)'::BOX3D, 4326 )
> but i have the next error when i try to run this sql in pgadmin
> "value too long for type character(6).
You are most likely joining a column that is char(6) with a column that
is larger, say char(10).
This is mostly likely in the "localidad_plano.codigopostal =
bpchar(inf_institucion.codigo_postal,10)" clause.
Does that help? If not, look at the definition of
"localidad_plano.codigopostal" - its probably char(6).
"bpchar(inf_institucion.codigo_postal,10)" is probably making a char(10).
Something like "text(localidad_plano.codigopostal) =
text(bpchar(inf_institucion.codigo_postal,10))" might work.
dave
