[postgis-users] POSTGIS connector - fixed version.
David Blasby
dblasby at refractions.net
Tue May 13 09:23:33 PDT 2003
Mark and carl (and others)
I have modified mappostgis.c so it is compatible with postgresql 7.3,
fixes the "extra funny characters bug", plus a few more fixes. I've
attached it to this message (I've sent it to the list a few times
already). The only known problem with this is that it leaks a little
bit of memory. Several people have been beta-testing this version and
they all report that it works 'great'.
I was going to fix the memory leak and commit it to CVS when I noticed
that someone modified the mapserver 3.7 version of mappostgis.c due to
changes in the map structure (cf. map.h). Until then, the 3.6 and 3.7
versions were exactly the same - now there are two different versions.
This is causing me quite a bit of grief because my new mappostgis.c has
quite a few modifications.
So, this version works with mapserver 3.6 and
3.7-up-until-they-changed-the-map-structure.
Dave's TODO:
1. figure out what was changed in the 3.7 version
2. fix memory leak
3. make a 'unified' version that will compile under 3.6 and the new 3.7
Until then, I suggest folks use the included mappostgis.c if you are
having problems with your installation.
Please tell me if there are any problems with this version (April 14).
dave
An embedded and charset-unspecified text was scrubbed...
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20030513/b17c8c31/attachment.c>
