[postgis-users] Compound Index? (Integer + Spatial)
Yurgis Baykshtis ybaykshtis at aurigin.com
Tue May 13 11:53:40 PDT 2003
That's right. Nothing complicated by the way. The only problem was that
those two libraries (btree-gist and rtree-gist) are not in the default
Postres build. So, it took some time for me to understand that.
-----Original Message-----
From: David Blasby [mailto:dblasby at refractions.net]
Sent: Tuesday, May 13, 2003 11:43 AM
To: PostGIS Users Discussion
Subject: Re: [postgis-users] Compound Index? (Integer + Spatial)
Yurgis Baykshtis wrote:
I forgot to mention that you can actually create a true compound index
using GiST, but it is quite complex and I havent actually done it.  If
you're interested in it, then you can check out the postgresql-hackers
mail list or see teodor and oleg's GiST webpage.
dave
postgis-users mailing list
postgis-users at postgis.refractions.net
http://postgis.refractions.net/mailman/listinfo/postgis-users
