[postgis-users] Error messages in PostGIS
Rosangela Silva
rosangela.silva at zenitpolar.com.br
Thu May 22 08:02:25 PDT 2003
Hello all,
I'm having two problems with PostGIS that I don't know
how to solve them. I don't have much experience with database
management. Could you help me, please?
I DROP a table continent, but I don't DROP the spatial
index before, and when I try to execute the sql again
I receive the message below:
$ psql -d geobusca -f continent.sql
ERROR: Relation 'continent' already exists
psql:continent.sql:1: ERROR: Relation 'continent' already exists
ERROR: Cannot insert a duplicate key into unique index geometry_columns_pk
WARNING: Error occurred while executing PL/pgSQL function addgeometrycolumn
WARNING: line 39 at execute statement
psql:continent.sql:2: WARNING: line 39 at execute statementng PL/pgSQL function
psql:continent.sql:2: ERROR: Cannot insert a duplicate key into unique index ge
ometry_columns_pk
In other case, I delete a record from a spatial table and when I try to
insert the same record again (with some changes) I received the message
below:
gisdb=# INSERT INTO wpt (wpt_waypointID, wpt_Name, the_geom) VALUES (9, 'TUN
L25', GeometryFromText('POINT(-46.63758 -23.97345)', 4326));
ERROR: ExecInsert: rejected due to CHECK constraint "$1" on "wpt"
gisdb=#
I'm using LATLONG/WGS84 and the wpt table is:
Table "public.wpt"
Column | Type | Modifiers
wpt_waypointid | bigint |
wpt_name | character varying |
the_geom | geometry |
Check constraints: "$1" (srid(the_geom) = -1)
"$2" ((geometrytype(the_geom) = 'POINT'::text) OR (the_geom IS NULL))
But I used the sintaxe bellow to create the table:
CREATE TABLE wpt (wpt_waypointID bigint, wpt_Name varchar);
SELECT AddGeometryColumn('geobusca','wpt','the_geom', 4326,'POINT',2);
What can I have to do?
Thanks
Rosângela.
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20030522/31926228/attachment.html>
